Spoon Caliper Help!!!!!!! Please
Old Apr 16, 2003 | 11:11 AM
jays2000's Avatar
Default Spoon Caliper Help!!!!!!! Please
Hi I try to install the caliper today and just realize that the stock pad is not fit the spoon caliper. the Brake pad seem to be smaller to fit in the caliper perfect can anyone help me what pad should i get. thank you
Old Apr 16, 2003 | 12:01 PM
beanolo's Avatar
Endless?
Old Apr 16, 2003 | 12:27 PM
AJ PwR's Avatar
The stock will fit to the Spoon calipers but you have to take off (cut) the clip thingy and the backing plates then you can have the pad go in smoothly.
Old Apr 16, 2003 | 08:21 PM
VeilsideAP1's Avatar
Like AJ said, the pad will fit with slight modification... I would personally go with endless.. They are the pads Spoon uses on it's track cars... Always a nice Endless sticker on the side....
Old Apr 17, 2003 | 05:35 AM
jays2000's Avatar
IF i use endless ccx do i still need to trim the clip or it just fit perfectly
Old Apr 17, 2003 | 12:01 PM
vapors2k's Avatar
Unless you get the mildest endless pads and the car is driven on the street, I don't see a reason why you couldn't run stock pads. They are cheap and don't dust very much and work out great. Just take a dremel to the backing plate and remove the 2 clips on 2 of the four pads. Not a big deal at all.
Old Apr 17, 2003 | 12:54 PM
jays2000's Avatar
IS this the right spoon caliper to fit the S2000. Also you guys mean the reatainer in the picture that i have to cut.
Old Apr 17, 2003 | 01:06 PM
vapors2k's Avatar
ahhh, you got the wrong calipers. Those are the older calipers for integra/civic. Isn't it weird how they have to run such a large pad? Anyways, sell those calipers and get the right ones.
-ardy
Old Apr 18, 2003 | 06:15 AM
ASMspec's Avatar
Vapors is correct. Those are the old civic calipers.. Stock pads will work as AJ mentioned. All you have to do is cut the metal reminder tab off.
You need the 4 piston monoblock calipers with the AP1 bracket kit.
Old May 8, 2003 | 05:58 PM
any luck with getting the right calipers yet?
