spoon horn button help
Old Apr 28, 2006 | 12:34 PM
quickysrt's Avatar
Default spoon horn button help
hello guys
just recieved a spoon steering wheel/hub(momo) and spoon horn button(made by momo too).
i have no clue on how to make it work. the stock wheel has been removed and the momo wheel/ hub is in place.
i have a yellow srs plug, the cruise control plug exposed.
please help
-hrc
Old Apr 29, 2006 | 03:11 AM
CoralDoc's Avatar
Why did you remove your steering wheel if you had no clue as to how to install the new one . You do realize that you will now throw an SRS code, right?
Now that my lecture is over, if the S2000 installation is anything like that on my Miata, you will need to identify which wire is the horn wire. Hint - it's not on the yellow SRS MPC (multi-prong connector). Fabricate an adapter to connect that wire (either through the MPC or by tapping on to the wire itself before it enters the MPC) to the male spade connector (the copper-colored thing on the back of the horn button) in the Spoon horn button. Then, make sure that the new steering wheel is correctly grounded and the horn should work when it's all put back together.
DS2k02
May 22, 2018 05:49 PM
2400s2k
Sep 21, 2013 03:17 PM
rev210k
Jun 18, 2012 03:11 AM
quickysrt
May 1, 2006 10:36 PM
