Spoon Snorkel-air box cover
Old Feb 18, 2005 | 02:48 PM
xviper's Avatar
Originally Posted by jkfox121' date='Feb 18 2005, 12:38 PM
Thanks for the tip, that's exactly what I was thinking. I'm going to take out the divider as well... I just doesn't make much sense to have it there.
If you don't have the "L" shaped tube in place, then the divider makes little sense. Honda designed this airbox to be many things. One of these is a "water trap". If you look at the "L" tube and how it lines up with the intake horn, you'll notice that there is a slit on the bottom surface of the passageway. The "L" begins slightly raised. Anything heavy like water, will fall down the slit and air goes through the "L". The water in the first chamber then falls out the hole at the bottom of the box. There is also another hole in the filter chamer for water that might get past the first trap.
There was a method to Honda's design. If you changed one part of it, the original design purpose is defeated. What else you do won't really matter anymore.
Old Feb 18, 2005 | 03:06 PM
jkfox121's Avatar
Thanks xviper for a great conclusion.
Old Feb 19, 2005 | 10:54 AM
Utah S2K's Avatar
I ran the snorkel (actually THE snorkel XV is referring to) for about 1 year with great success. Then I moved on to the AEM CAI. The snorkel was a prototype made of carbon fiber provided to me by Richard Ming (Import Developement) and was a Spoon knock-off. It worked very well as should the Spoon unit. Tech 2 Motorsports makes a really slick carbon fiber sheet that accomodates a snorkel and sellsfor about 175 bucks.
Utah
Old Feb 19, 2005 | 09:38 PM
jkfox121's Avatar
Thanks for the input Utah.
I already ordered the "slick carbon fiber sheet" from the tech 2 group buy
Should have it Monday!
Toyofan
Feb 10, 2008 04:53 PM
amielo
Jul 16, 2007 12:33 PM
tangelina
Nov 8, 2006 12:12 PM
dollag
May 14, 2005 02:46 PM
Clovis
Oct 20, 2000 07:28 AM
