Spoon Thermostat
Old Aug 18, 2006 | 01:18 PM
S2_PHENOMENON's Avatar
Default Spoon Thermostat
Hello all! I'm not sure if this whould belong here, but I was wondering if anyone here knew if a spoon thermostat would work on an 06 S2000? Thanks.
Old Aug 18, 2006 | 03:33 PM
Slows2k's Avatar
It will fit in the housing, but it's unknown if it will cause a DTC with the 06's new PCM.
Old Aug 19, 2006 | 04:59 AM
mikey k's Avatar
I seem to recall reading the "cooling mods" cannot be done on the 06 due to the PCM change.
Old Aug 19, 2006 | 10:40 AM
AJ PwR's Avatar
I think the fan switch and the rad cap will be ok to install cuz I have tried that already.
Old Aug 19, 2006 | 11:10 AM
mikey k's Avatar
I was under the impression the fans were controlled by the ECU?
Old Aug 20, 2006 | 04:56 PM
Slows2k's Avatar
The PCM switches the fans based on the coolant temp switch. The PCM also monitors how long the car takes to reach operating temp, and can set DTC's if the thermostat sticks open. Lower temps fans switch and Thermos stat may be enough of a change to set the DTC's.
Old Aug 21, 2006 | 06:41 AM
Fyrestrike's Avatar
The fan switch does not fit but the thermo does. I've had the thermo on for 5 months and no DTC's to date.
Old Aug 21, 2006 | 01:38 PM
Thanks for all of your guy's input.
Rdizzle
Nov 24, 2009 07:08 PM
Spookee
Apr 26, 2007 10:23 PM
S2Kdreamz
Jan 8, 2005 12:07 PM
billy_i_vtec
Aug 2, 2004 06:57 PM
a6s7d8
May 14, 2003 06:39 AM
