spoon x brace installation trouble
Old Dec 30, 2000 | 02:36 PM
josh3io's Avatar
Every bolt fit except the rear right one. it was to the right of the hole by about 3mm. anyone else have trouble like this?
Old Dec 30, 2000 | 03:29 PM
JohnA's Avatar
Some of the members the Xbrace attach to are themselves movable by loosening the bolts they are attached with. Loosen them, put all bolts in and then tighten.
JohnA
Old Dec 30, 2000 | 03:32 PM
cdelena's Avatar
Are you sure you have it turned the right way? I would think that these are all identical and mine and others fit perfectly. It is made to pickup the existing bolts so it is not an even X.. get under there and look again.
Old Dec 30, 2000 | 04:34 PM
josh3io's Avatar
i have it in the right way, it's just that one bolt hole is off by just enough so that hitting it with a mallet will bring it just close enough so that i think it will fit, and then doesn't. >:/
Old Dec 30, 2000 | 04:42 PM
Prolene's Avatar
Is seems it just "don't fit"! Either x-brace defect or chassis (forbid) dimension deviations. Maybe measure dimensions between bolt holes of the chassis (both cross and box) and compare with others who have not had x-brace problems. If same, then another x-brace you need!
Old Dec 30, 2000 | 05:23 PM
2x6spds's Avatar
[QUOTE]Originally posted by Prolene:
[B]Is seems it just "don't fit"!
Old Dec 30, 2000 | 05:27 PM
Prolene's Avatar
Originally posted by 2x6spds:
____________
Yoda said that, right?
LOL, I think it was Gandalf in Lord of the Rings!
Old Dec 30, 2000 | 09:05 PM
krazik's Avatar
Administrator
Josh, I hade the same problem.
Loosen all the bolts on the stock tie bar and move it around some. The holes in my stock tie bar were slightly off and once I loosened it up, it all went in nicely.
I can dig up some pics if you don't know what I am talking abooot.
-r
[This message has been edited by krazik-s2k (edited December 31, 2000).]
Old Dec 31, 2000 | 06:12 AM
pfb's Avatar
pfb
I assume you had not tightened down any of the bolts until you had them all started?
Old Jan 2, 2001 | 10:14 AM
josh3io's Avatar
krazik, i'll give that a try next time i get a chance.
pfb - no, i didn't torque them until i was done. but the last one wouldn't line up, i.e. couldn't get started at all.
i think i'm going to follow prolene's advice and measure, anyone w/ an x-brace to compare measurments?
