Spring Rate Conversion
Old Aug 15, 2003 | 02:26 PM
fly_S2K's Avatar
Default Spring Rate Conversion
Is there a site or program that can convert lbs/in into kg/mm? If not, can someone tell me how much 450lbs/in, 350lbs/in is in kg/mm? Thanks.
-Johnny
Old Aug 15, 2003 | 02:36 PM
fly_S2K's Avatar
Found this chart. Wanted someone else's opinion if it had correct information.
http://www.anzwers.org/trade/hsdracing/elk...conversion.html
Thanks.
-Johnny
Old Aug 15, 2003 | 02:37 PM
mwy23's Avatar
1in = 2.54cm = 25.4mm
1kg = 2.2lbs
do the math...
good find on the chart tho...
Old Aug 15, 2003 | 02:55 PM
fly_S2K's Avatar
I was hoping I didn't have to do the math, because I have a lot of spring rates. But if the chart isn't correct, I guess I'll have to do so . Thanks.
-Johnny
Old Aug 17, 2003 | 07:18 PM
slick rick's Avatar
25.4 X 2.2 = 55.88
So you take the kg/mm number and multiply by 55.88 to get the in/lbs.
IE 8kg/mm = 447lbs/in
Old Aug 17, 2003 | 07:22 PM
fly_S2K's Avatar
Thank you. I also found out that google can do the math for me, thanks to twohoos.
Old Sep 23, 2003 | 03:26 AM
honda9krpm's Avatar
Thanks for the links guys
I just found that my front springs are 11
Old Sep 23, 2003 | 08:24 PM
CMiS2K's Avatar
11K? that is good. Nice and stiff, if they are stiffer than the rear, then you will reduce throttle/power oversteer due to the SC!
Old Sep 24, 2003 | 12:02 AM
honda9krpm's Avatar
thanks CMiS2K, but 600lbs is likely going to cause premature renal failure for me
I hope it's double progressive
Apex1.0
Aug 3, 2014 01:05 PM
bobby.is.rad
Aug 1, 2012 04:47 PM
icecreamballer
Jun 30, 2005 01:07 AM
SpeedxRacer
Nov 21, 2003 03:23 PM
