spun bearing help
Old Apr 21, 2009 | 06:15 PM
downloader's Avatar
if you spun a bearing your connecting rod is done, most likely the crank too.
Old Apr 21, 2009 | 06:42 PM
Ultra_Nexus's Avatar
Unless you caught it in the supremely early stages.
One I spun earlier:
Old Apr 21, 2009 | 10:41 PM
prolux's Avatar
how long was your engine running with a knock to recieve that damage?
seconds? minutes? days?
Old Apr 22, 2009 | 12:25 AM
jonner's Avatar
Spun mine ages ago....Marked the crank...Just got a short block and reused the head...Drop her in and away you go...
That was my solution....
Old Apr 22, 2009 | 03:02 AM
prolux's Avatar
O yeh new block, easy as pie right?? lol. Can anyone give me any indication to HOW LONG they had the engine running to what extend their damage was. I just wanna know do you get like INSTANT extensive damage, or after a few minutes? or does it take a bit more. Or is it just like asking how longs a piece of string?
Old Apr 22, 2009 | 03:17 AM
lotus7racer's Avatar
When you spun the bearing, no way you can stop the engine in minutes.
I guarrantee you drove the car a lot of miles before identifying the problem....it's normal for all of us.
Cylinder scoring can happen anytime in any given situation when you spun the bearing. I know you are worried, there is nothing you can do except open the bottom and hoping the cylinder is ok.
That's all you can do and hope.
There is no time table when this things happens.
Old Apr 22, 2009 | 06:26 AM
AdN's Avatar
AdN
how many kms did you have on the engine? i didnt think a spun bearing was general wear and tear.
isnt it caused from not revving high enough during normal daily driving?
Old Apr 22, 2009 | 08:34 AM
prolux's Avatar
It was caused by oil starvation
Old Apr 22, 2009 | 05:24 PM
downloader's Avatar
Hey Prolux , all this talk about what you can save, and how long the motor was running when the bearing was spun is useless. Take down the pan and have a look, see what is damaged. remove the valve cover and check your cam, oil starvation can hurt a lot of things. You really can tell what price the engine overhaul is going to cost unless you know what needs to be changed. Good luck to you
Old Apr 23, 2009 | 12:19 AM
jonner's Avatar
As was mine....
