Sputtering?
Old Feb 20, 2007 | 06:12 PM
millertown15's Avatar
Default Sputtering?
Alright, I dont wanna beat a dead horse on this one but here's my problem. A couple of times a day under stop and go traffic my car "bucks or sputters" like its out of gas. I have read on here that people say its normal and alot do it but something is wrong. There is no way it does it 4 to 5 times a day, sometimes more. What could it be? Fuel pump going out, bad injector, I have no clue. Nothing aftermarket is done to the motor. Please help. Thanks guys.
Old Feb 20, 2007 | 06:22 PM
C U AT 9K's Avatar
Does it occur usually after you let off the gas and let the clutch in (say as you're coming to a stop)? If you were to tap the throttle and "bounce" the rev once, would it drop down to way below idle, nearly stalling out in some instances?
If so, that'll be your MAP sensor. Look in the FAQs for the MAP Whack thread, or just go buy a new one (updated from hardtopguy.com, i believe) like I did.
Edit: Just noticed you have an 01 like me, so I'm 90% sure it's the MAP sensor...
Old Feb 20, 2007 | 06:32 PM
Not quite stalling out. But it does drop a little. If im quick I can catch it. While it is sputtering I can press the clutch in and keep my foot depressed on the gas just a small bit, it sputters, then clears up. Maybe 2 seconds of sputtering then it clears out??? Map sensor huh. Hell ill try anything hahaha
Old Feb 20, 2007 | 08:12 PM
kidjetta's Avatar
mine does it too, I wonder what it is anyone help out please?
Old Feb 21, 2007 | 06:55 AM
C U AT 9K's Avatar
You can both try the MAP whack, it takes 5 seconds. Since you both have AP1's from 00-01, I'm fairly positive that's your problem.
Old Feb 21, 2007 | 07:52 AM
mxt_77's Avatar
Your post says "nothing aftermarket is done to the motor", but your sig lists a cold air intake, test pipe, & exhaust. All of these things affect how the motor behaves and the readings it gets from its sensors.
With this said... I have no additional information for your problem. Sorry.
Old Feb 21, 2007 | 10:16 AM
I have not updated my sig. I went back to the stock intake box. The exhaust has nothing to do with my problem. It did this when I was FULLY stock.
Old Feb 21, 2007 | 10:17 AM
Went to the zone and had the computer checked. Everything read ok. I even tried to unplug the MAP and run the car but it wouldnt do anything. So I think the MAP is ok. Would this have anything to do with the Air Idle Control Valve???
Old Feb 21, 2007 | 10:23 AM
Clone's Avatar
mine does that shit too, and the "map whack" didn't work for me, unless I somehow followed the directions wrong (which I'm 99.9999% sure I didn't).
I've considered just replacing it, see if that would do the trick... but I dunno.
Old Feb 21, 2007 | 10:45 AM
^^ Yeah but its 70.00 bucks and its non refundable... BOO!!!! lol
