Sputtering, stalling, lean conditions
Originally Posted by WLAURENT,Apr 23 2007, 11:19 AM
I am 100% certain that it is not MAP, and about 90% certain it is not TPS. My TPS shows a smooth change (both the output voltage and what is displayed by the OBD scantool) through the entire range. MAP sensor was wacked, swapped and replaced with a new one.
If I disconnect the O2 sensor (also brand new) the car runs very good in open-loop - just very rich and it will not idle very well. I could see the MAP sensor effecting idle, but do not see how the TPS would cause the idle to be rough if the reading is steady-state.
boy does this sound familiar. my car was doing similar all summer, had to do map whacks usually every couple days. acted fine when the weather was cold, but when it started to get warm again I'm getting the stuttering etc again, though not as bad yet. I've always had the burbling/popping at off throttle, and the idle is normally really rough (swings between vibrating the whole car and occasionally so smooth I can barely tell its running). I'm pretty sure its running real rich too, just put new exhaust on this week and its already got black on it, though it looks like its spitting carbon instead of a smooth coating.
gonna keep my eye on this thread.
my00 86k
my00 86k
Originally Posted by WLAURENT,Apr 23 2007, 10:59 PM
Load calculations are based on the MAP readings. Mine are normal per the Helm's guide.
Originally Posted by icemans2k02,Apr 24 2007, 05:59 AM
not sure about the comptech unit but the vortech had a timing box and a map clamp. if you are supercharged your map readings will be different. I did have the same issue as you guys and spent a full week in the shop. all I had to do was put new plugs in and change the gap to a not so agressive one .34 what are your gaps now?
My plugs are at 0.035
Originally Posted by WLAURENT,Apr 24 2007, 09:00 AM
I put the car back to stock and it still did the same thing - so it is not the map clamp.
Originally Posted by icemans2k02,Apr 24 2007, 08:12 AM
from your previous posts you said that your car was running the same as a stock S. i was just making sure you knew that it would be totally different. try gapping to a larger size .044 and are they new plugs? mine fouled out after 2 months of use on my car
I have since put the SC back in service and re-installed the Iridium NGK plugs gapped at 0.035"
Originally Posted by WLAURENT,Apr 23 2007, 08:58 PM
When I unplug my AIC the car throttles up and down rapidly.
I tried the plug the two hole thing and it died - but I am not sure why that would indicate the IAC is bad.
