Sputtering, stalling, lean conditions
Old Aug 13, 2007 | 10:05 AM
  #151
millertown15's Avatar
Originally Posted by ShocK,Aug 11 2007, 05:49 PM
supercharged?
REALLY!!!??? I know its supercharged. lol. I was trying to find the link to the other thread but cant find it. Thanks for the link WLaurent.
Old Aug 13, 2007 | 01:44 PM
  #152
ShocK's Avatar
sure is a weird looking setup, but if it works its good I guess.
Old Aug 16, 2007 | 09:12 AM
  #153
krikke_s2000's Avatar
Originally Posted by ShocK,Apr 24 2007, 11:52 AM
Straight from the manual pg. 318: Block both upper and lower ports in the throttle body with your fingers while engine is running. Does your engine stall? Yes- replace IAC valve. No-Check for vacuum leaks, test the throttle body section 11-122
hello i'm new here i have a question to you ho have replaced the IAC valve what happens when you close the two holes in the throttle bodie does the engine stal then or what does it do my car is also stottering between 1500-2000 rpm
thanks and grtz from belgium
Old May 15, 2008 | 07:52 PM
  #154
ShocK's Avatar
I ran some Gumout fuel injector cleaner through my system and the car has not hesitated since. I'm waiting for a really hot day to test it out entirely to make sure but so far so good. Kinda makes sense the injectors could be dirty and cause sticking under hotter conditions. Shoulda thought of that a long time ago, going to run one more bottle just for good measure and see what happens.
Old May 27, 2008 | 03:07 PM
  #155
ABCVTEC's Avatar
I have recently had these problems with my car. I've been CTSCd since about March but it didn't start happening until after I went to Church's Automotive to have my FPR adjusted. Todd there said I was running too lean so he opened my FPR all the way. Ever since then I've been having these problems with the sputtering below 2500rpm, and today for the first time my engine completely stalled while in neutral.
I also have a CEL for running rich. Could this all be from that I'm running too rich? I'm about to go clean my IACV and go from there.
Old Jul 2, 2008 | 01:52 PM
  #156
mrmumbels's Avatar
was a fix ever decided? i got the same thing going on with my car. I just hit 104k miles.
Old Jul 2, 2008 | 02:50 PM
  #157
mrmumbels's Avatar
tried the link above cleaning out that little passage way and it wasn't dirty. Took the whole tb off and cleaned all the gunk out to no avail.
Old Jul 2, 2008 | 07:17 PM
  #158
ShocK's Avatar
I swapped my injectors for ones with 18k miles on them, I still have not fixed the problem. So far I have changed to Spoon TB with new MAP and TPS, New IAC, New EVAP Purge Solenoid, swapped primary 02 for one with lesser miles also. I am going to try to block off all the vacuum lines to see what happens.
Old Aug 8, 2008 | 09:03 AM
  #159
ninety2slow's Avatar
I kinda wish I found this thread before buying my S2k.
My car wasn't accelerating rough, but it definitely had a rough idle and got so bad that it started shutting itself off. This is all during hot temps outside. Anyway, the dealership has replaced the injectors with new ones, and my air pump under the bumper was bad, so they have replaced that as well.
I don't have the car back yet, but the technician said my car is running perfect now and idles great. The car hasn't died on him, so I hope my S2k problems are over.
Once I get the car back, I think I am going to clean out that MAP sensor passageway just to be cautious. It makes me wonder if my S2000 had a ticking time bomb that just waited to go off at 68,500 miles.
Old Aug 8, 2008 | 07:38 PM
  #160
ShocK's Avatar
I never figured out the problem, but a lady pulled out in front of me and now I'm going to part out my car so my problem is solved HAHA.
