Stall on idle
After searching on the forums for many hours. I can't seem to fix my idling issue. Every time I come to a complete stop the idle will drop down and stall. Even with the car in neutral. I can be rolling at 1mph and it wont stall, until I come to a complete stop. Also if I'm driving around and throw it into neutral and coast the rpm will drop really low but less likely to stall while moving. And sometimes my tachometer will read 800-900rpm but the feel is much closer to 200rpm.
So far what I've done:
1. Replaced the TPS.
2. Cleaned the IAC valve.
3. Cleaned the MAP connector and the sensor and also sprayed carb cleaner into where the sensor goes in.
About the car:
It's an 2000 AP1 with a Comptech SC. I first noticed the idle issue around the time I lost a bolt for the SC mount. It would drop down but never stall. The issue eventually just got worse and worse. Even after replacing the mount bolt.
I've read up on the issue but haven't found any definite solutions, but it seems to be a common s2k issue.
ANY HELP IS GREATLY APPRECIATED. Driving around used to be fun, but the stalling every time I stop is a major inconvenience.
About the car:
Did you reset the ECU after replacing sensors? OBDII stores values for long and short term fuel trim. Most of the cases I have seen with "stop-stall" were the result of SFFT/LTFT imbalance of some type. Temperature change is the biggest culprit.
Assuming you have already pulled any set or pending codes, disconnect the battery for 10 minutes, reconnect, and see if the problem still exists...
Utah
Utah
Utah
Utah
