stalling out in neutral
Old Nov 10, 2003 | 08:21 PM
hyun83's Avatar
Default stalling out in neutral
I have no idea why or the reason as to why this happens every once in awhile. Today I go to my car, put the key in, it the clutch, and press the start button. The engine started like usual. However, when I let go of the clutch the car started shaking like I was about to stall out and almost did until i pushed the clutch in all the way. I was not in reverse or 1st gear. Does anyone have any insight as to why this might have happened? I have 18k on my car and its an 00. Well, I dropped the car off at Honda and i'll find the results out tomorrow. I hope its all covered under warranty
Old Nov 11, 2003 | 05:40 AM
ItalianBucwheat's Avatar
If it happened recently since we started getting the colder mornings here in NJ then it is just your ecu not use to such cold starts. It takes a week or so of cold starts for the ecu to get its act together then it usually goes away unless you reset the ecu. If not I have no idea. I get this on cold starts all year long becuase I have no ecu fuse in. Once warmed up it goes away.
Itchy Dick
Mar 19, 2011 01:59 AM
AlbatrossS2K
Apr 27, 2010 04:46 AM
Spies
Oct 6, 2009 01:37 PM
andrewh_11
May 9, 2006 11:07 PM
jumper1564
Dec 22, 2003 06:51 AM
