Start Up Problems
Old Sep 25, 2007 | 09:05 AM
SOHCmyDOHC's Avatar
Originally Posted by DeeDubya,Sep 25 2007, 05:13 AM
Could be defective battery. The engine is harder to crank when it's hot. I would have the dealer check the battery for sure.
If it barely cranks it might be the battery
Old Sep 25, 2007 | 09:24 AM
Siepel's Avatar
Originally Posted by pyrocpu,Sep 24 2007, 01:09 PM
Hold the throttle down a bit (say 25%) on a hot start. ECU sees the throttle position and automatically leans out the air/fuel mix condition under hot start. It should light up easier. If this doesn't work, try 50% throttle next time, and so forth. The second the motor catches and turns on its own, foot off gas & finger off start button!
Fascinating advice
Just to make sure you know and as a friendly heads up, this car is not equipped with a carburator.
Take care,
Siepel
Old Sep 25, 2007 | 10:39 AM
nearwater4me's Avatar
My '07 does this sometimes, too.
I didn't think it was a problem.
I guess you're fine.
Dan
Old Sep 25, 2007 | 02:42 PM
EternalLx's Avatar
Same here I just figure it was heatsoak.
Nothing to worry about.
Old Sep 26, 2007 | 12:34 PM
Rdizzle's Avatar
I tried this on my 07 and couldn't reproduce this problem--how many degrees are the places where you live and this is happening? It was about 60 degrees outside when I tried it and my car was previously running for about an hour before turning it off.
Old Sep 26, 2007 | 05:35 PM
s2kforlife's Avatar
^i think they're talkin about 80+ degrees
Old Sep 26, 2007 | 10:51 PM
Mystiqueskillz's Avatar
When I take my car in for warranty services, can I take it to any Honda dealership or do I have to take it to the one I bought the car from because the dealership I bought the car from is a good 40 minute drive.
Old Sep 27, 2007 | 05:38 AM
DeeDubya's Avatar
Any Honda dealership should provide warranty service, however, I have always found that most prefer to service the cars that they sell. The dealership gets refunded for warranty work.
With a battery, like tires, they might make an adjustment. Example, if the battery warranty is 36 months and you have owned the car for 12 months then they would adjust the cost and you would have to pay 1/3 the cost of a new battery.
Old Sep 28, 2007 | 11:45 AM
8kGoodENuff's Avatar
Same happens here... probably just heat soak. Nothing to worry about... just hold the Engine Start button down a little bit longer... hehe.
Andre
Old Oct 3, 2007 | 09:41 AM
pyrocpu's Avatar
Originally Posted by Siepel,Sep 25 2007, 12:24 PM
Fascinating advice
Take care,
Siepel
You're not serious are you? Have you driven, owned, or operated a carb-equipped vehicle? Friendly heads-up: applying throttle to a carb-equipped car upon startup RICHENS the A/F, not the other way around. On modern FI vehicles, applying throttle LEANS the A/F. Hot-start conditions require less fuel than cold-start. The more throttle applied when cranking, the ECU backs off fuel.
Try and educate yourself before spawning spurious apathy.
