Starter?
Billman250 the noise was very loud come to think of it. Is the timing chain tensioner/starter motor change a big job to do. Worried about the timing chain tensioner sounds like that's going to do a lot of damage if fails.
Think I give Honda a ring tomorrow.
Thanks for the info.
Just to add the noise only happened 3 times in the last week just straight after starting, it has started more times good with no noise????So not 100% sure what the problem is... Thanks again for the help.
Originally Posted by billman250,Feb 19 2006, 03:07 AM
Back in the day, I started a thread called "starter afterun noise". I thought it was a sticking starter.
Turned out to be the timing chain tensioner. The s2k starter is held to extremely accurate spacing from the ring gear. I'm not feeling it's the starter.
You want a solid 100% answer, do a 10 sec walk around vid, with good audio of course, and post it here
On first listen I would swear it's the traditional problem of the solenoid not retracting because it has "that sound" and ONLY occurs on startup and goes away in less than 2 seconds. But sometimes it sounds more like a belt squeal from hell (I have Comptech SC too). I'm sure it's loud enough to be heard 50' away.
But then I noticed that it NEVER occurs when the engine is warmed up. And in a few cases it actually seemed to occur a second or so AFTER the engine is running and I've released the start button. In other words, the engine cranks, starts, stops cranking and runs normally, short pause, loud grinding/rattling/almost-squealing noise for one second.
So one time I actually pressed the start button after thte engine was running to compare sounds, and while it was similar, it's definitely different than the noise I get on startup.
I'll try to get a recording next time, it's a pretty awful sound. Oh, I'm at 168k, original chain & tensioner.
It is NOT the starter.
Modifry.....the walk around vid was meant to catch the first two seconds of startup. It usually happens in the AM, right after the engine fires. Lasts about 1 or two secs, the immediately stops. It's a very rapid sound, like a playing card in the spokes of a bicycle wheel. For the cost and ease of install, I would try it. I know how you like to experiment
