starting noise
Old Oct 27, 2012 | 11:58 AM
transpersonal's Avatar
Default starting noise
Hello! New member here, with an '07 that I bought new, 39,000 on the clock now. More often than not, I get a wheezy, grindy noise following the starting of the car, lasting about a second. This happens mostly when the temperature outside is 60 degrees or less. Any clues before I take it in?
Old Oct 27, 2012 | 02:28 PM
s2w0w's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I get a similar noise right after the car is started that lasts about a second. Haven't figured out what it is so interested if anyone has solved this. BTW, I drive a 06.
Old Oct 27, 2012 | 03:07 PM
drobinson1692's Avatar
I believe I've read in the past it's due to the starting staying engaged too long. Search for the grind at start.
Old Oct 27, 2012 | 04:35 PM
CoolGuy094's Avatar
Read up on these links:
http://www.google.com/search?client=...+starter+grind
Old Oct 28, 2012 | 02:38 AM
INDYMAC's Avatar
You need a new starter. Cold weather is when it's first noticed.
Old Oct 28, 2012 | 05:28 AM
CoolGuy094's Avatar
Please research and don't listen to ^^^
dyllan
Sep 16, 2023 06:31 AM
uahmad3
Jun 8, 2017 10:27 AM
S2K_Mikester
Oct 26, 2015 08:48 AM
jyeung528
Sep 17, 2007 12:28 PM
Billman250
Mar 4, 2007 05:44 AM
