Is this the steering angle sensor?
Old Mar 17, 2014 | 09:03 AM
jimboslice's Avatar
Default Is this the steering angle sensor?
So I installed my NRG short hub, put everything together, took her for a spin and noticed that my wheel was off by like a tooth. So i pulled everything apart, and when i removed the hub, the green plastic piece went with it.
I didn't reef on it or man handle anything in anyway. I thought it was weird, and figured I broke something, but put it back together anyway. I then noticed that my VSA and (!) lights were stuck on. Turning the wheel 360 in either direction didn't reset the lights either.
I'm wondering if what i broke was, in fact, the steering angle sensor? I'm aware that i don't have VSA now, which isn't much of a concern to me. but i'd still like to fix it at some point.
Thanks guys.
Old Mar 18, 2014 | 08:37 AM
jimboslice's Avatar
Anyone? I'm being told that it's the body switch. Is this the same thing?
I know that I should pick up a manual at some point, but after doing extensive image searches, the only thing I can find that looks similar is what i found below.
http://www.hondapartsunlimited.com/h...me=body-switch
EDIT: disregard. Looks like they're one and the same. However, the part I listed is for pre 2006 models. That's why they're so cheap. 06+ are something like $200.
Old Mar 19, 2014 | 07:59 AM
Stratocaster's Avatar
What you are seeing it part of the NRG hub. Looks to me to be a horn connection. I know the steering related sensors are not inside the passenger section of the car. They are under the hood.
Old Mar 19, 2014 | 12:58 PM
jimboslice's Avatar
That green piece wasn't there when i took the hub out of it's box prior to install. oh well. i don't really care if i don't have vsa anyway.
shind3
Sep 2, 2023 09:49 AM
Fat
Feb 3, 2018 08:57 AM
maranelloboy05
Oct 25, 2014 11:36 AM
Monacos2k
Apr 5, 2014 11:20 AM
