steering rack & accident
Old Feb 17, 2010 | 05:15 AM
mikeyhomes's Avatar
Default steering rack & accident
hi guys,
i got into an accident last week, i spun out and hit a tree.
it wasnt that fast on impact so i did a bit of fender damage, however the side of the wheel took the brunt of the impact. so now besides the fact that one wheel is a liite more turned than the other, it feels like there is no power steering when i turn the last final rotation right. turning left is like normal.
i checked the wheel and it is not bent.
all the control arms seem to be straight, subframe hasnt moved.
there is a contant grinding noise from what seems like the inside of the black canister from the steering rack.
i pulled it out and saw no cracks and the "worm" looks fine.
from what i gather i think if i replace the entire unit i should be fine.
does this seem like im doing the right thing?
thanks
mike
Old Feb 17, 2010 | 06:26 AM
jimbosr1's Avatar
i would get you wheel issue and have a aliament done.you might have more damage then you think.your steering may be corrected when the other stuff is repaired.
Old Feb 17, 2010 | 07:08 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Ill bet the bank you bent the worm gear that extends out of the rack.
raise the front, and turn the wheels side to side with the carr off. If you feel binding, you screwed up the rack.
A rack is very expensive....you are welcome to send it to me, and I will fix it wont be the first time Ive repaired a bent s2k rack.
Old Feb 17, 2010 | 07:21 AM
fatjoe10's Avatar
^ I've seen 2 like that already . You can find an used one for like $100-150 on the board. Good luck!
Old Jun 8, 2010 | 09:49 PM
Hockey's Avatar
I'm about to swap out my rack, which has been pulling sharply to the right after a fender bender some time ago. It has been re-aligned a couple times so I know that is not the issue. The steering wheel will actually rotate to the right when the car is started while up on the rack... good.
The goood thing is that I found a used rack for a good price but am now looking for a DIY swap procedure. Anyone have a place I can find it. I'm plenty handy with tools but haven't had to tackle this one yet.
-Hockey
Old Jun 8, 2010 | 10:14 PM
Opc's Avatar
Opc
what is that kinda clicking thing that happens with the steering rack, i just did transmission and think i ****ed up my rack
Gaffa
Jan 17, 2015 03:39 PM
agy2k2
Aug 12, 2014 11:49 AM
modestgod
Dec 2, 2010 10:03 PM
dreamer
May 2, 2005 03:08 PM
mas
Jul 18, 2003 12:02 PM
