Steering rack install- VSA lights on
Last weekend I got a CR steering rack + torque sensor installed on my 09 AP2 and afterwards both VSA lights are on (the VSA and ! Triangle). It's not low brake fluid; I also completed the relearn torque sensor to neutral position procedure and the lights are still on after approximately 100mi of driving.
What I did notice was that the steering wheel only turns about 1 turn to the left but about 1.4 to the right, starting from center neutral position. Is this normal, CR (and I guess base model) owners? Or did the shop botch the install?
Thanks all
Thanks all
When does the light come on? Immediately after you start the car, or after you manipulate the steering wheel?
Thanks all
Thanks all
You need to reset the torque position sensor, for one
https://www.s2ki.com/s2000/topic/860...da-pgm-tester/
I think they're trying to re-center the rack now. They're going to take measurements and make sure it's properly centered; ie, neutral position is the exact center when turned from lock to lock on both sides. Is this how it is supposed to be? I have heard from other sources that you are supposed to be able to turn the wheel left more from the center position than turning it right (so that u turns can be properly executed?). Can anyone do a quick check on their car to see if the turns are the same for left and right?
Alexander Startsev
Feb 7, 2017 02:40 PM
