Steering Wheel Click
Old May 18, 2009 | 05:50 AM
tugsta's Avatar
Default Steering Wheel Click
Hi All,
Im wondering if any of you could help me shed light on my clicking steering wheel problem.
Its a MY03 just hit 30,000km on the odo.
The issue:
About 2 weeks ago i drove my car to work (its my daily driver) and noticed that the steering wheel felt slightly heavier than usual, not to the point i couldn't turn the wheel but just felt noticeably heavier, there was no EPS light so i thought maybe it was my tires.
After adding some pressure the steering wheel still felt heavy. I thought maybe im just being paranoid about it and left it.
Last weekend I noticed whenever i am turning my steering wheel from left to right it starts to click, the sound of this click seems to be coming from right behind the steering wheel itself.
I have actually made two videos showing this problem and i hope someone on here can help me diagnose this issue soon. Im relatively new to my s2k, i've only had it for about 6 months.
I would appreciate anyone who can help me on this as i would like to rectify the problem before it gets any worse.
Video 1;
[media]http://www.youtube.com/watch?v=uSLt_EFTuR8 [/media]
Video 2;
[media]http://www.youtube.com/watch?v=isGY_APz_G8 [/media]
Thank you.
Old May 19, 2009 | 04:03 AM
tugsta's Avatar
any ideas? anyone?
Old May 20, 2009 | 05:20 AM
tugsta's Avatar
one last try (cry) for help
Old May 20, 2009 | 05:47 AM
Saki GT's Avatar
Sounds like a loose bolt. Try turning the wheel slower - does it make the same noise?
Old May 20, 2009 | 06:10 AM
tugsta's Avatar
theres still a slight noise.
I cant seem to feel where the vibration is coming from.
any other ideas? if something is loose it doesnt sound like a bolt.
Old May 20, 2009 | 06:49 AM
negcamber's Avatar
There are two universal joints...the upper one may be causing that noise.
There is also a ball bearing in the steering column just behind the steering wheel. That can also make noise and make the wheel feel like it has some play in it.
Old May 20, 2009 | 07:35 AM
tugsta's Avatar
thanks for the input, does this mean my steering column is damaged and requires service?
do i need to replace the bearings?
im going to take it to my local mechanic this weekend to look at, i just wanted to be able to goto him and advise him on what to look at.
I havent driven my car since i started hearing that noise incase i make it worse. I work long hours so hard to find time to go and see my mechanic.
Old May 20, 2009 | 06:13 PM
negcamber's Avatar
I don't know that there is a way to rebuild the steering universal joint or replace the ball bearing assy in the wheel hub. Actually...just looked in the Helms and it says to replace the entire column if either are causing problems.
shamusodoofus
Mar 12, 2011 10:25 AM
robert112
Apr 26, 2007 05:02 PM
Urge
Feb 6, 2007 03:44 AM
krysdafur
Apr 18, 2005 10:02 AM
Scambo
Feb 13, 2003 01:17 PM
