sticky clutch
Old Nov 6, 2010 | 05:10 PM
skyler2k's Avatar
Default sticky clutch
Hey guy I have an 05 S its only got 52k miles on it and my clutch went along with the pressure plate so I bought a act heavy duty pp and a performance clutch I got them both put in and the pedal is still the same at engagement point as it was when my clutch went it feels like something is in the way I have to push really hard only at engagement point but after that it moves fine it doesn't stick to the floor no problems with it getting stuck coming back up even through engagement point only when I first push it in and if I keep it right at engagement point I can shift like there nothing wrong but if I fully disengage it, its hard again. Sorry if there is another post I looked and couldn't find this exact problem anyone have any ideas what it could be?
Thanks Craig
Old Nov 6, 2010 | 10:58 PM
aresk3b's Avatar
you should use the search, this is a common problem
https://www.s2ki.com/forums/index.php?showt...&#entry17949908
this was my scenario, I also have Act PP
Old Nov 8, 2010 | 04:54 AM
allstar71's Avatar
I had this prob. and it was the throw out bearing sticking.
Old Nov 8, 2010 | 10:15 AM
flyingtoaster's Avatar
Was the throwout bearing properly lubricated with Honda high temperature urea grease?
Old Nov 9, 2010 | 06:46 AM
allstar71's Avatar
Probably not when I had the issue. I bought the car in july and issue started in august. It is now and works fine. I was just giving some options as to what his problem might be. My s2k is an 05 and had the issue at 49000 miles....so it sounded like it could be the same issue.
Brndon
Mar 18, 2013 02:49 PM
SeanSerino
May 21, 2010 11:25 AM
08s2000CRbackinblack
Aug 1, 2009 03:39 AM
spazbaboon
Jul 19, 2009 08:36 PM
Rob_s2k
Nov 30, 2008 06:02 PM
