Stock Brakes Problem
Old Jun 27, 2012 | 09:45 PM
kotsapas's Avatar
Default Stock Brakes Problem
so it was football night and i was rushing to a place to watch football..not too fast though..anyway
as i arrived i felt that the car stopped a bit too rough,
i tried to take off to check if everything is ok, then i would come to a standstill as i was pressing the brakes
one more time, the same thing..
i turned it off, watched the football and then after 2 hours the problem was gone..!
But my question is, WHY? and what??
is it that my stock brakes need service or something?
my best guess is that one of the pistons in the caliber got stuck..
but again why? in the racetrack i push it 10 times more..how can a 10min drive harm them..i didnt push them that hard..
should i go check it out? or is it nothing?
has anyone experienced anything like this?
Old Jun 28, 2012 | 07:18 AM
franky's Avatar
check both side if the calipers if they are burning hot when that happens again. you might of mistaken some power steering fluid for brake fluid. that happened to me on my truck. Flush it and put in new fluid.
Old Jun 28, 2012 | 07:26 AM
S2KIrishman's Avatar
s2000's dont have power steering fluid ...op, i had a caliper stick on me a couple years ago...ended up being the passenger side, i could tell by driving it for 10 mins and then got out and felt the heat differnece coming off of the wheel
Old Jun 28, 2012 | 08:14 AM
kotsapas's Avatar
havent changed the fluid for a while..
the fluid is the correct one
Old Jun 28, 2012 | 08:39 AM
daktruckie99's Avatar
One of my calipers sticks every now and then after the car sits for a while. I also track my car and they brakes are fine there.
When I sense it sticking, I usually give the brakes a few hard pulses and it frees up.
-Mike
Old Jun 28, 2012 | 08:53 AM
kotsapas's Avatar
-Mike
ok good to know if it happens again..
cant it be fixed though?
Old Jun 28, 2012 | 08:55 AM
Rebuild or replace the caliper are the only real options.
-Mike
Old Jun 28, 2012 | 09:00 AM
kotsapas's Avatar
will consider a big brake kit..that will fit ap2stock rims..
any suggetions?
Old Jun 28, 2012 | 09:05 PM
kotsapas's Avatar
oh by the way, it did it again last night..:/
Old Jun 29, 2012 | 12:59 AM
kotsapas's Avatar
Originally Posted by hecash
any suggetions?
I converted my front calipers to the 2003 Accord V6 Coupe type. The project took me about 2 hours of my time, $US 330 to Honda for re-manufactured calipers, $US 140 for new stainless steel brake lines to mate to the Accord calipers, $US 25 for 1.5mm rotor spacers to move the rotor to the center of the caliper and $US 120 for Hawk Blue race pads.
The brackets are a direct mount but you must switch the Accord left side to be used on the S2000 right side to keep the bleeder valve on the top of the caliper. You get 30% more brake surface and more ability to modulate braking for trail braking.
I'm very happy with this conversion. They will fit OEM and any other wheel.
very nice modification/upgrade...
will have it in mind..
a bit difficult to find that kind of accord in my country though.. ( v6 )
thanks for your input
