Stock Valve Spring Installed Height
Old Apr 27, 2005 | 07:59 AM
cjb80's Avatar
Default Stock Valve Spring Installed Height
Does anyone know what the stock installed height of the valve spring is? I did a search which yielded nothing.
k,thanks
Chris
Old May 2, 2005 | 02:55 PM
Greenlight's Avatar
The valve stem installed ht. as shown in the service manual is:
Int. Valve Stem Installed Ht.
Std. (New) 44.1 - 44.4 mm (1.736 - 1.748 in.)
Service Limit: 44.7 (1.760 in.)
Ex. Valve Stem Installed Ht.
Std (New): 44.2 - 44.5 mm (1.740 - 1.752 in.)
Service Limit: 44.8 (1.764 in.)
This meaurement is taken from the valve spring seat to the tip of the valve and IS NOT the same measurement needed when setting the valve spring installed height using aftermarket springs.
The dimension used for aftermarket springs is the dimension from the valve spring seat to the underside of the valve spring retainer. I took a quick measurement on a spare stock cyl. head that I have and the number is approximately 1.640 inches (41.6 mm).
I hope this helps.
Greenlight
912S2k
Jan 2, 2018 03:12 AM
cryptotek
Feb 16, 2010 08:48 AM
ChefJ
Apr 15, 2009 08:46 PM
honda_f1
Apr 24, 2005 03:49 PM
