Stops reving at 5-7k when temp gauge is low
When I try to get above about 5k rpms when first starting off when the car has been off for awhile and the temp gauge is low I get stuck and it won't go any higher than 5 k-6k almost like it gets stuck in vtec or hitting the rev limiter. What's my problem?
First post guys so don't grill me if I did it wrong
The car will not exced 6,400 Rpm when "cold" (AP1). Many peeps use 3 bars of temp, again AP1, as a reference to when your good to go. Someone can give the AP2 bar rule as I don't know it off the top of my head. In reality the temp relates to oil viscosity. The cut off is actually regulated by fluid pressure to the V-TEC solenoid which is affected by temperature. Cold fluid is thicker and does not provide enough pressure.
Utah
Utah
Originally Posted by Utah S2K
The car will not exced 6,400 Rpm when "cold" (AP1). Many peeps use 3 bars of temp, again AP1, as a reference to when your good to go. Someone can give the AP2 bar rule as I don't know it off the top of my head. In reality the temp relates to oil viscosity. The cut off is actually regulated by fluid pressure to the V-TEC solenoid which is affected by temperature. Cold fluid is thicker and does not provide enough pressure. Utah
