Strange clunking noise
The only recent thing I have done was add a test pipe, as you can hear in the video it sounds like a clunking of gears or something. I went underneath and when the sound is created the test pipe doesn't shake nor does the exhaust. It must be something else, I don't know if its the starter as the car also will not start, neither will it jump start. Not sure what is wrong with it, haven't had much time or room to check it out as I have moved.
View My Video
Any suggestions would be appreciated!
View My Video
" I went underneath and when the sound is created the test pipe doesn't shake. "
This noise is heard with the car stationery? Or only when it's moving?
" I don't know if it's the starter as the car also will not start, neither will it jump start. "
The starting problems occurred right away the test pipe switch-in?
I'd prolly review all the steps taken in placing the test pipe. The noise has the sound of potential big $$$ fix. At least, the volume in your video is quite noticeable. It does sound like something rubbing or interfering with a part which is rotating.
Good luck!
Good luck!
The noise appears irrelevant to whether or not the car is stationary, it comes when the clutch is depressed.
Good luck!
Good luck!
I'm beginning to ponder whether it is the throw out bearing or the input shaft bearing, if anyone has had to replace these cares to chime in that would be of great help!
BUMP
I would appreciate some input from other members. I even have a video yet there's practically no one chiming in as opposed to other threads. Am I just despised? I sure do give my fair share of input...
Anyways back to the problem, if it disappears when the clutch is engage with the car moving or stationary that leads me to believe that it has to be something with the contact point of the tranny and engine hence it being the clutch. Would this logic or deduction be accurate ? Seems to make sense to me.
Just to be sure, did you re-check the secondary O2 sensor was tightened all the way? Can't see the vid right now, but I know that I had a rattle after doing the test pipe and it was just the O2 sensor was loose and knocking on the test pipe (not the sensor itself but the CEL fix adapter and spark plug defouler combination I had).
