Strange dyno results
Old Nov 13, 2012 | 12:51 PM
RobEvans's Avatar
Also could you advise me on colder plugs please? I replaced mine with NGK R PFR7G 11s premium platinums only 5000 miles ago.
A part number would be great!
Old Nov 13, 2012 | 01:02 PM
MB's Avatar
MB
Member
Why colder plugs?
Did the dyno guy monitor your knock readings?
Old Nov 13, 2012 | 01:22 PM
RobEvans's Avatar
Yes he did, i asked to to double check the knock and he said there was none. Just for some unknown reason the ECU was shortening the injectory duty thus leaning out the AFRs and losing power one the pull after the cold one. The first pull was always fine but the next was always lean and down on power.
He told me the engine should run rich on the second run as it is hotter. All i can think is that the ECU is thinking the air is hotter than it actually is and putting in less fuel as hot air is less dense?
Im planning on changing the radiator, cleaning the fuel injectors, changing the plugs, maybe the MAP and intake temp sensor and then going for some more dyno runs in 4th gear instead of 5th.
I welcome any advice!
Old Nov 13, 2012 | 01:30 PM
MB's Avatar
MB
Member
Well if its not a misfire I'd look at anything which will pull fuel or timing, so the MAP and IAT sensor would be up there.
Old Nov 13, 2012 | 01:33 PM
RobEvans's Avatar
What spark plugs would you suggest MB?
Would NGK R PFR7G be ok?
Old Nov 13, 2012 | 01:55 PM
chris_barry's Avatar
I use NGK R5672A-8
Based on my experience I wouldnt use the platinum plugs on a race car or a car doing hard work.
Old Nov 13, 2012 | 02:02 PM
MB's Avatar
MB
Member
NGK 7746 iridium a is what I use. Full season of racing and they are perfect
p800bry
Aug 23, 2009 01:10 PM
hyperpm
Sep 26, 2008 04:41 PM
JustinC
Sep 14, 2007 08:23 AM
AzNxKuKu
Feb 23, 2004 12:05 PM
