Strange Idle problems, only sometimes.
Old Sep 18, 2010 | 07:22 PM
Calamari's Avatar
Default Strange Idle problems, only sometimes.
Hi,
my 01 has been doing some funny things lately, This doesnt happen all the time, but its really annoying when it does.
When I drive, and i come to a stop at a red light, as soon as the rpm hits the 800-1000 mark, it drops suddenly to like 400-500 (Dont know exactly without proper instruments, all I see is 4 bars on the rpm cluster) and the car vibrates as if its going to stall... then it returns to normal 800-1000 idle.
Any ideas on what I should check for?
Thanks
Old Sep 19, 2010 | 11:17 PM
totaleclipse's Avatar
check your plugs and wire. If your plug is really bad and need replacing do a "SeaFoam" treatment first then replace your plugs and wire. SeaFoam might kill your plug, but it will clean the crap out of your engine. 1/3 for 5 mins only.
Old Sep 20, 2010 | 03:18 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Do not sea foam. Plugs are not the problem. This car does not have "wires" for the plugs.
Really totaleclipse?
Old Sep 20, 2010 | 03:36 AM
240toS2k's Avatar
MAP whack comes to mind. Another thing is check the tightness of your plugs, my car started idling like shit when my #2 spark plug started backing out, I caught it before anything really bad happened thankfully. Try resetting your ecu though that probably won't do much.
Old Sep 20, 2010 | 06:35 AM
brliv's Avatar
I have a 2005 S2K and my problem is nearly identical. Just before I come to a stop, depress clutch and rpm decreases considerably. The recovery time is too slow for decent performance. These symptoms occur when the car is really warmed up. Never happened before dealer serviced with new hydraulics and clutch/flywheel.
Dealer says this is normal for S2000. Nonsense, never did it before.
Old Sep 20, 2010 | 06:53 AM
Jay2000's Avatar
Mine's done that for years, the idle drops for a second or 2 and bounces right back up. I think all my other ones did it as well. I never thought much about it.
CBR 2000
Jun 16, 2010 11:29 AM
CosmosMpower
Feb 5, 2009 10:23 AM
REVZ TO9
May 18, 2007 05:05 AM
demonderrick
Nov 19, 2004 10:56 PM
Morangie
Jul 15, 2002 04:15 AM
