What causes a spark plug to crack?
Old May 17, 2007 | 12:19 PM
REVZ TO9's Avatar
Banned
Default What causes a spark plug to crack?
One of mine just did and got it replaced, but it sure caused mis-fires and a compression leak. Unless I had a faulty spark plug, what else can cause them to crack? By the way, I baby my car and dont drive it hard. I have only 59K miles and I had the new spark plugs put in around 8 months ago, so they werent even that old before one of them cracked recently.
Old May 17, 2007 | 01:32 PM
stphotographer's Avatar
Usually running lean, heat, and incorrect gap. Most likely you had a defective plug. I had one in my last set, caused idle and low rpm acceleration issues.
Old May 17, 2007 | 06:37 PM
SenderGreen's Avatar
What type of spark plugs?
Old May 17, 2007 | 08:36 PM
REVZ TO9's Avatar
Banned
OEM NGK
Old May 17, 2007 | 08:48 PM
Originally Posted by Ztopgun28,May 17 2007, 08:36 PM
OEM NGK
Did you check the gap and torque them correctly also? Sounds like I'm blaming you, I'm not. Probably defect like stphotographer said.
Old May 17, 2007 | 09:05 PM
REVZ TO9's Avatar
Banned
actually it could have been a gap problem like u say unless it was defected. This honda mechanic guy (not dealership) did them for me so it is possible he could have gapped them wrong. I think he said they came pre-gapped, but I was told afterwards that they arent pre-gapped. So I think he may have not gapped them right too maybe
Old May 17, 2007 | 09:16 PM
OEM NGK's do come pre-gapped. I have only done mine once, so I'm by no means an expert or even an authority. I checked the gap anyway as I have read it is good practice. There was indeed very slight differences on the gap of 2 of them. One was a little "snug" (narrow) one was little "loose" (wide) I'm pretty sure they were all within spec. They are pretty difficult/stiff to gap. I just made my best effort to make the gaps uniform on all the plugs, within spec of course.
I guess they do come gapped, but you're supposed to check them anyway. So the mechanic guy is/was half right.
Old May 17, 2007 | 10:27 PM
REVZ TO9's Avatar
Banned
oh ok
Old May 18, 2007 | 04:35 AM
silvers2k01's Avatar
What should the gap be?
Old May 18, 2007 | 05:05 AM
Spark Plugs:
NGK: PFR7G-11S
DENSO: PK22PR-L11S
Electrode Gap:
Standard (New): 1.0-1.1mm (0.039-0.043 in.)
Service Limit: 1.3mm (0.015 in.)
speakeasy2009
Aug 28, 2011 06:17 PM
essi1553
Aug 22, 2010 04:15 AM
HonCBRf2
Jun 28, 2008 12:42 PM
S2K_Ownz
Apr 26, 2003 05:49 AM
