Stretched Timing Chain?
Developed a ticking noise from the engine area. Poked around with a steth and it seems to be coming from where the timing chain is located. I'm currently running a modded TCT (inlinePro), but I took it off anyway and sandblasted the worm gear to see if it helps. Put it back together and the ticking remains.
A little before the ticking became very obvious, my car started running very rich at idle (11-12 afr). What are the chances that the chain is stretched? Could a stretched chain throw off my timing and cause my car to run rich at idle?
Outside of the ticking and the rich idle, the car seems to be running fine.
To elaborate on the ticking noise, at idle it sounds normal with random tick, tick, ticks every now and then. When I give it a little gas in neutral (around 3k rpm), the ticking becomes more consistant. Same while driving, light throttle ticking is consistant.
Any ideas on what else it could be? Also I did a valve adjustment recently and it did not fix the noise.
Thanks!
UPDATE: Just uploaded a video
http://www.youtube.com/watch?v=py69VPmJNAs
Thanks!
I have the ballade tct and I get a buzz around 3000rpm, Im almost convinced its the tct itself, Im pretty close to just buying an oem tct to see if it goes away.
