Stripped allen bolt on top of shock
While doing a spring install, I somehow managed to strip the allen nut that holds the shock still while you loosen the assembly. What are my options?
I guess I could go buy a new assembly, but that would be costly. Any others?? I need to find a solution today.
Thanks
Jeff
Thanks
Jeff
This happened to me on my last car. This is what I did:
Since I was replacing my shocks w/ aftermarket shocks, I did not need to keep the stock shocks. I bought a pair of locking pliers, which you can set how tight/small a grip you want, and then I locked them on the part of the shock that rotates w/ the bolt. I then held that while unbolting the top bolt.
This scratches up the shock where you grip it w/ the pliers, but if you are replacing your shocks anyways, I think its a good method to get the bolt off.
hope this helps...
mike
hope this helps...
mike
FF2Skip
Mar 28, 2004 07:16 PM
