Stripped hole
Old Feb 6, 2023 | 05:06 AM
A.O.'s Avatar
Originally Posted by AM4R
Bumping this after a long time. Does anyone know if I can use a bolt from a hardware store (is it strong enough) or if 90142-S04-004 006 002 fits?
I would think a grade 8 bolt would do fine!
Old Feb 6, 2023 | 06:30 AM
B serious's Avatar
Grade 8 is a rating for SAE bolts. Metric bolts are measured in class, not grades.
A metric bolt with "8.8" written on it doesn't mean grade 8. It means class 8.8, which is roughly equivalent to a SAE grade 5.
Tricky, yes?
You need a metric, class 10.9 bolt. I can't remember if the factory bolt has a loose washer attached, or if its a flange bolt.
Either way, its a JIS, reduced wrench bolt.
Thread size M8x1.25 for the fronts. Should be about 16-20mm long.
Or just buy the factory bolt because its easy.
Old Feb 6, 2023 | 08:52 AM
AM4R's Avatar
Tricky, yes?
Thanks, it's a actually the seat belt buckle bolt that I'm after - you can't seem to buy it from honda unless you buy the whole buckle receiver too which is mad!
Old Feb 6, 2023 | 08:56 AM
Jub's Avatar
Jub
^Factory bolts had a flat washer and a split washer.
Old Feb 6, 2023 | 10:58 AM
A.O.'s Avatar
Tricky, yes?
Thanks for the lesson.
Old Feb 6, 2023 | 12:19 PM
B serious's Avatar
No, you cannot buy a seat belt buckle bolt from a HW store.
Seat belt bolts are 7/16-20 SAE Grade 8 thread size. Which is commonly available, normally.
BUT...what makes them unavailable from a HW store is that they are a specific length, flanged shoulder bolt with a 14mm drive, which has to be assembled with all the washers exactly correctly.
Buy a used seat belt assembly or look for a part out that's selling the bolts.
I'm assuming you're using the stock seat belt receiver?
Seat belt bolts are a bit of an anomaly. They're always 7/16-20 SAE grade 8, due to a safety standard.
Old Feb 6, 2023 | 12:34 PM
A.O.'s Avatar
AH HA!! I was right then!
Old Feb 7, 2023 | 11:46 AM
B serious's Avatar
lol yes, I suppose you were
gombey43
Mar 27, 2018 02:32 PM
Cawdor
Aug 5, 2011 09:41 AM
AR-9
Aug 9, 2010 11:39 PM
