Strongest bolts on the market?
Old Aug 27, 2008 | 09:33 PM
dominion's Avatar
Default Strongest bolts on the market?
Where do you guys buy your titanium bolts?
Old Aug 27, 2008 | 10:51 PM
jasonn's Avatar
bolts for what? if you mean lug nuts for wheel, you can get it from our vendors. the ones that carry titanium rather than the titanium look is Tommy @ go-tuning.
Old Aug 27, 2008 | 11:03 PM
mikegarrison's Avatar
Define "strongest".
And yes, bolts for what?
If you really need a good quality bolt, you don't want any of this stuff sold by auto or hardware folks. You want aerospace grade bolts, like the AN series. The quality control is better.
Old Aug 27, 2008 | 11:54 PM
a_zepeda926's Avatar
Originally Posted by mikegarrison,Aug 28 2008, 12:03 AM
Define "strongest".
I work with the stuff.
Old Aug 28, 2008 | 05:31 PM
topless!'s Avatar
Typically, I thought that an SAE grade 8 is the strongest bolt out there with respect to tensile strength. There are other specs that are similar such as ASTM A490 but the ones that I believe are readily available are grade 8 though.
Old Aug 28, 2008 | 05:57 PM
JDMQuip's Avatar
Grade 8 bolts are the strongest 'common' bolts. You can get them in different coats. ie: galvanized, zinc, black oxide, etc. But aerospace bolts are stronger than your typical USS/SAE bolts. Whatever anyone tells you Stainless steel bolts are NOT stronger than your typical grade bolts. Stainless steel is a soft metal.
chubbys2k
Feb 22, 2016 07:11 PM
Carl Bourbon
Dec 29, 2013 05:56 AM
peters2000
Nov 29, 2009 07:19 AM
mikecl713
Nov 21, 2004 03:02 PM
