Struggling to get coilovers to fit! Help!
Hi hope I'm in the right section for this post apologies if I'm not.
i have a 2001 ap1 and I'm having trouble fitting my front drivers side coilover, the bottom cup that holds the spring seems to be in the way of the control arm, I can wind the spring up higher but I'm not sure if it should be sitting the way it is in the first place, it's like the coilover is sitting slightly to the right of the control arm, maybe something is bent? I have attached pictures of the standard shock and the coilover fitted for reference, any advice is much appreciated if this is normal then I will wind the spring up and carry on!
thanks!
thanks!
That's what I'm trying to find out, if i knew it was that I'd just replace it but trying to figure out what's wrong first never had a problem till I tried fitting the coilovers
Holy corrosion city Batman! Id lean towards a bent control arm. There is so much deterioration on those I wouldn't be surprised if your getting metal fatigue at this point.
You must not live in a rust belt area. That is nothing. Plenty of worse normal cars on the road.
Now, an S shouldn't be driven in winter in these areas so it doesn't get like that. Just not worth it. 3 months of the year putting 95% of the deterioration on the car. Better to drive it 3 seasons.
But that rust isn't going to cause ca failure or anything.
