stuck plug socket
Old Nov 18, 2012 | 11:11 PM
greenbean57's Avatar
Default stuck plug socket
K so I'm clearly an idiot. The duct tape I used to tape on my extension somehow got loose and the spark plug socket is stuck in the well. Going to try to buy a tool to extract, but until then. If I unscrew the NGK plug and screw it back on, is that ok? Or will I have to buy a new plug. I guess the question is once it is fully seated, if I remove it will that coating be stripped, invalidating the plug?
Old Nov 19, 2012 | 06:36 AM
spets's Avatar
You can reuse plugs.
Old Nov 19, 2012 | 07:38 AM
Uncoolron's Avatar
Yeah. You will be fine unscrewing it retorguing it back.
Old Nov 19, 2012 | 08:07 AM
Yoohoo's Avatar
You might have to apply some anti-seize lub if you take it out.
Old Nov 19, 2012 | 09:48 AM
dwight's Avatar
I've had good luck with reinserting the extension into the plug and then jiggling as I try to remove the spark plug socket from the spark plug, but not I use locking extensions so it isn't an issue.
http://www.amazon.com/Neiko-Tools-pi.../dp/B001JGTFAA
Old Nov 19, 2012 | 03:29 PM
Thanks for the link dwight, I was looking at some crazy one from google searches, and locking sets were like 130 bucks or so. 25 dollars is def within my price range!
Old Nov 19, 2012 | 04:13 PM
downloader's Avatar
just push the extension back onto the socket and unscrew the plug, then when all is out re-install the plug you don't have to buy anything
Old Nov 19, 2012 | 06:23 PM
darcyw's Avatar
you're not alone...i've done that before, until i bought the longest spark plug socket i could- i think mine's about 6 inches long...my extension, that is.
good luck
darcy
Old Nov 20, 2012 | 03:44 PM
johnzal's Avatar
I did the same thing with duct tape.. Remove all the duck tape from the top. And force the socket extension in
Sent from my SPH-D710 using Tapatalk 2
speakeasy2009
Aug 28, 2011 06:17 PM
2000sx
Oct 7, 2009 11:21 AM
DJHohum
Mar 27, 2002 10:50 PM
Zoinks
Nov 9, 2001 08:56 PM
