Stuck Trunk
I just installed my carbon fiber trunk and closed it for test fitment and forgot to plug in the cable to the electronic open switch the glove compartment. Now i can't open it. What can I do now?
Thanks in advance
Thanks in advance
You will have to go through the panel behind the seat, and stick like a long pole, close hanger type deal through the opening, past the spare tire, and then past the rear trunk trim (might need some force to get those close lose)then to try to access the emergency trunk release. This is the method that I've seen posted and used many times.
Its on the trunk latch itself (the plastic piece that you had to bolt to the trunk using the 3 bolts), it glows in the dark, its a latch that you have to move it to the left to manually release the trunk. If you use a flash light you can probably see it. Its the emergency trunk release latch.
Looks something like this:
can someone with a MY00 confirm?
Yeah, I don't think the 00 have them. So you have a huge problem if you did not hook up the key cylinder to the latch. I think you would have to pull a lot of the interior out of the car to get access to hook up the wire to open it.
