Stuttering and Stalling
Old Dec 22, 2020 | 10:58 AM
abalagurak's Avatar
Default Stuttering and Stalling
Hello. I have tried searching the forums for a solution to my issue but haven't found anything exactly specific to my issue. I was driving on the highway and in 6th gear gave it a little gas and the car started stuttering like crazy. RPMs started dropping and I put it into neutral and coasted to a stop. I turned the car off and then on and the issue went away for about 5 minutes but then started happening again. What was happening at first was that the car would start up and idle fine. Revving it would feel fine too, and even backing out in reverse gear would feel normal. I have changed the spark plugs since and cleaned the map sensor. At first there was no CEL but after cleaning the map, the CEL came on and now the car does not even idle correctly, it stalls. I'm going to get a code reader and see what the cel might be, but besides that I'm at a loss. Has anything like this happened to anyone before? If you put the car into gear, the engine stutters and rpms start to drop.
Old Dec 22, 2020 | 11:23 AM
Chuck S's Avatar
Which car? Your profile and signature photo don't match.
CEL is normally an emissions issue but you need to read the codes.
-- Chuck
Old Dec 22, 2020 | 11:38 AM
abalagurak's Avatar
2005 ap2.
Old Dec 22, 2020 | 02:06 PM
windhund116's Avatar
Yeah. Post the CEL codes.
Old Dec 23, 2020 | 06:51 AM
abalagurak's Avatar
So it turns out the ground wire to the map sensor is ripped off somehow. The CEL was P0108 so I am hoping that is the true source of the issues.
outeiroj
Mar 12, 2019 01:32 PM
itm
Oct 30, 2018 01:35 PM
m3bmwcab
Mar 3, 2016 06:00 AM
Richvow
Feb 28, 2016 05:01 AM
