Suspension
I need to find some good sway bar links and sway bar bushings and i think my rear sway bar is aftermarket because it is powder coated orange but it has no name on it. would like to get energy suspension bushings but i do not think that they carry them for the S yet.
They carry just about every size of bar bushings.
Measure the bushing that's currently on there look in their catalog or call ES I can guaranty they will have the size or within a 1/16" of it.
As far as the links they are the same as 96-00 civic end links
Aftermarket civic links will work for the S take your pick there are about a dozen variants.
Thanks for the info, just found the ES rear sway bar bushings at the store and ordered the front like you said they were universal fit but just get done installing the rears and they fit perfect. I will look up the links thats good info to know thanks
Check part numbers to make sure 100% about the links I had them side by side and they looked the same
Hondapartsdeals.com compare 99-00 Si links and s2k links.
fendiracing
Jul 4, 2016 04:17 PM
