Suspension and Cat Bolt Help
Old Apr 14, 2013 | 05:45 PM
Dsteven21's Avatar
Default Suspension and Cat Bolt Help
Hey wondering if these are sway bar end links? i have just noticed they broke off and been driving the car for a while and nothing has happened. Wondering if i should replace with oem ones or aftermarket? Need the part number
[attachment=37413:2013-04-13_18-46-12_124.jpg]
Also what are the spring bolts for the catalytic converter? mines were replaced with regular one because i had to change them due to rustiness. Would i have to put the oem ones back right away or will it last with none spring bolts. Would getting a test pipe solve this i have an Hks dual exhaust freshly installed.
Attached Thumbnails Suspension and Cat Bolt Help-2013-04-13_18-46-12_124.jpg   Suspension and Cat Bolt Help-2013-04-13_18-46-04_979.jpg
Old Apr 14, 2013 | 05:56 PM
HondaS's Avatar
those are sway bar end links yes, and using a regular bolt will eventually break i know because i tried this. anyways you can get some on ebay for like 5 bucks each for the bolt and spring or from the dealer your looking at like 15 bucks
Old Apr 14, 2013 | 06:13 PM
Dsteven21's Avatar
how long did your bolts take to break?
Old Apr 14, 2013 | 08:56 PM
HondaS's Avatar
about 10 mins on a curvy mountain road lol. i had 1 spring bolt and one regular bolt and the regular bolt broke so i ordered one on ebay
Old Apr 15, 2013 | 09:24 AM
Dsteven21's Avatar
What does anyone recommend to replace the end links? the part # please
Old Apr 15, 2013 | 10:00 AM
HondaS's Avatar
52320-S2A-003
i believe thats the one you are looking for
Old Apr 15, 2013 | 07:32 PM
Dsteven21's Avatar
are ebay ones okay or does it have to be oem? im gonna measure to see if its the exact length
Old Apr 17, 2013 | 04:51 PM
HondaS's Avatar
That's up to you man, you can get oem ones for about 40 bucks ebay ones are probably half that maybe 30. if your on a tight budget go for it but if not they are fairly inexpensive to just get oem
End005
Aug 18, 2014 06:58 AM
InVTEC
Jan 8, 2013 07:44 PM
s1lentGPW
Mar 1, 2008 12:17 AM
vtec9
Apr 30, 2006 11:26 AM
ryang
Jan 20, 2003 07:39 AM
