Suspension Problem
Old Nov 10, 2006 | 01:46 AM
s2k_dreams's Avatar
Default Suspension Problem
Hi all,
Once again I find myself coming to my fellew s2ki-ers for help. I cannot say how much this community has helped me, but what I can say is that I greatly appreciate the effort and level of care the members show by helping me out. Thanks guys; and girls of course.
I apologize for the long explanation in advance.
Well here's the story:
Some basic facts:
MY'00
Stock everything
80k miles (I bought it with 75k miles on it)
I have a chirping noise coming from the front driver's side. The sound it makes is exactly that, a chirp, like a cricket chirping (Chirp, chirp chirp...you get the idea.) It does not sound like a screeching (I suspect it is not the brake pads being too worn.)
When I drive the car with weight transferred to the rear it chirps less (under acceleration) and it cirps at a constant speed as well as deceleration. I've done braking tests and I find that when I pump the brakes it chirps louder and when I release the brake the chirp wil end. (This is not a continuous chirp, just a single loud chirp.)
When I am turning it stops chirping unless the car goes over a bumpy surface.
When I turn the steering wheel while driving at highway speed (30-50 MPH) it chirps at the intial move of the steering wheel.
It chirps when I turn the steering wheel while stationary.
I've tried to push on the car at the strut towers to try and bounce the car up and down but could not produce a chirp.
Sometimes when I push the tire (driver's side) with my foot it chirps, sometimes it doesn't.
I can't figure out what is making this chirping sound and it is driving my crazy.
Note: I have crashed the car once but the impact was frontal and only the bumper was damaged. The tires and wheels did not make contact with the guardrail. In fact the crash was at an angle (read: my car slid sideways and the front bumper grazed the gaurdrail)
Also the alignment is off a bit. The steering wheel is turned slighty clockwise (right) when I am driving straight. So when I let go of the steering wheel the car veers left but only very gradually.
I cannot confirm whether the alignment was off before the crash or not because I crashed it on my second day after I bought the car.
I am positive that the car did not chirp (squeek) before the accident.
I have heard a few random guesses from people who I have described this noise to:
Driveshaft
Control arm(s)
Steering rack
Sway bar
End links
My guess is that there is a nut or bolt missing and that a metal bar is rubbing against another metal bar, causing this chirping sound, which sounds a lot like metal to metal contact.
Any educated guesses would be very much appreciated and please include some reasoning to your responses if possible.
Thanks so much guys!
Old Nov 10, 2006 | 06:01 AM
jguerdat's Avatar
Just a SWAG:
Have you checked the torque on each wheel nut? If a wheel ismoving slightly I could imagine getting a noise from the metal surfaces rubbing. You could take advantage of this check to remove the wheels and inspect the brake pads at the same time...
Old Nov 10, 2006 | 01:42 PM
s2k_dreams's Avatar
I've taken off all the wheels a couple of times and am positive that the lugs are torqued properly. I have this ongoing paranoia about the lugs not being on correctly and having a tire fly off on the freeway
Thanks for taking the time to make a guess. I appreciate the response though.
Old Nov 18, 2006 | 03:03 PM
snakeeater's Avatar
Ball joint? Loose nut on hub allowing the wheel bearings to move? Have you tried taking the weight off the front wheels and moving things around to listen for the noise?
Old Nov 20, 2006 | 10:22 AM
RT's Avatar
RT
my wild a$$ guess would be Ball Joint too ..... good luck
Old Nov 20, 2006 | 08:34 PM
mikegarrison's Avatar
Ball joints do seem like a reasonable guess. Get in there and visually inspect all the bushings, too. And look at all the welds on the A-arm brackets to see if they are unbroken.
Old Dec 19, 2006 | 10:24 PM
s2k_dreams's Avatar
I solved the squeek problem. Well actually Darin at Westend Alignment did. It turned out to be a loose crossmember bolt.
Old Jan 14, 2007 | 08:20 AM
clag's Avatar
Dude, I am really glad you worked it out, but just for play I gotta throw in a little "I told ya so":
https://www.s2ki.com/forums/index.php?showt...0&#entry9056309
[QUOTE=clag,Nov 12 2006, 10:16 AM]s2k_dreams,
s2k_dreams
Jan 28, 2007 06:51 PM
s2k_dreams
Nov 10, 2006 01:37 PM
cyber_x
Aug 8, 2005 02:08 PM
KaMxiKaZe
Jun 11, 2005 04:09 PM
KYS2000
Nov 12, 2002 09:49 PM
