Suspension problem. Please help!
Old Aug 12, 2008 | 01:20 PM
vollrathian's Avatar
Originally Posted by Nickamsweet,Aug 10 2008, 06:40 PM
Have you changed the struts at all? or is this a complete stock suspension?
are the struts ok? maybe one is leaking
Old Aug 13, 2008 | 01:47 PM
samsam5886's Avatar
that's a possibility! thanks for bringing it up
but would the one that's leaking (lower) also hang not as low as the other not leaking strut? hmm...
Old Aug 13, 2008 | 02:04 PM
Ray's Avatar
Ray
Blown dampers do not cause the car to sit lower.
Dampers are suppose to dampen the spring motion, not support the weight of the car.
However, if you have blown damper on one side, the spring on that side will be oscillating much more. This will cause the spring to sag due to fatigue and make the car sit much lower.
If you have the original springs from 2000, then it's time for new suspension.
This happened to one side of my rear and the tire on that corner was actually rubbing the fender when going over a bump.
Old Aug 23, 2008 | 05:57 PM
samsam5886's Avatar
I found the cause! finally! the right lower arm is bent upwards. I already ordered a new set.
vassosva
Feb 1, 2010 07:43 PM
LegacySHO
Aug 22, 2009 12:15 PM
Leo Gets
May 28, 2009 10:18 AM
Stiggywig
Nov 28, 2007 01:41 PM
pikkashoe
Apr 24, 2006 04:24 PM
