Swapping a F22 in my ap1
Old Jun 23, 2012 | 05:49 PM
JeffreyMartin's Avatar
Default Swapping a F22 in my ap1
I just got the F22 in my ap1, got it all back together! Started it a couple times, then took it out for a couple times around the block twice. I parked it on the street and it won't start now. I put the key in, everything lights up and then i pushed the start button and nothing. no crank, nothing. Tried jumping it, that wasn't it. Then I unplugged the negative side of the battery just to see if it needed reset and nothing. If you have any advice, I would really appreciate it.
Old Jun 23, 2012 | 05:56 PM
Oh yeah, the car wouldn't rev about 3000rpm.
Old Jun 24, 2012 | 12:38 AM
Leviisbigred's Avatar
just go over everything again. check the wires to starter etc
Old Jun 24, 2012 | 01:04 AM
FutureDevilDog's Avatar
this is why I hate the electronic portion of the car, one little mistake can cause a big problem
Old Jun 24, 2012 | 03:32 PM
JUSTINTHECOASTIE's Avatar
Definitely re-check all of your wiring. Did you use your AP1 harness or AP2?
Old Jun 24, 2012 | 04:45 PM
zbrewha863's Avatar
Sounds like an electrical issue with the starting for sure.
As far as not revving above 3k rpm, could be electrical or you could have valvetrain issues. My old AP1 engine did that just before it broke a retainer and dropped a valve into my cylinder. Did you have the AP2 engine checked out before you dropped it in? Not trying to freak you out, but just sharing my experience. I hope it's something little like a sensor or bad wire/ground.
Old Jun 24, 2012 | 08:11 PM
2003AP1's Avatar
Best bet is checking all wires again like states above. Pay close attention to all the grounds.
Old Jun 25, 2012 | 05:49 AM
Stratocaster's Avatar
Did you fill it with oil?
Old Jun 25, 2012 | 07:27 AM
AP1Theory's Avatar
What year is the AP2 engine? If you are using a '06 or newer engine, you have to swap out the cam and crank pulse wheels with your AP1 engine.
89CRXSi
Oct 1, 2018 02:11 AM
BeeVee
Jan 8, 2012 03:00 PM
Live_Wire
Dec 25, 2007 05:01 PM
