Symptoms of needing a valve adjustment?
Originally Posted by truekakaka,Oct 29 2007, 03:10 PM
thanks guys i think i'm going to have to have an adjustment. when i drive a hear this very soft ticking sound coming from somewhere under the hood.
As for spark plugs, are there any signs that you need to replace them?
thanks jyeung
is this a normal engine sound at idle?
http://www.youtube.com/watch?v=zNmHh0_UhZg
mine sounds very similar (maybe i'm being paranoid)
since its at idle, it can be TCT or noisy valves which need valve adjustment.
TCT noise ticking would increase with increased rev's...
otherwise its a valve adjustment that needs to be done.
If its a MY00 as your sig indicates I would have them adjusted just for peace of mind. Its less than 150 bucks at the dealer. It may also be the TCT as it is a wear part. That piece is only 130ish at the dealer and can be installed in less then 10 minutes with very simple tools in your garage.
can't really hear it at idle, when i'm slowly accelerating, at around 3000rpm you can hear a fast tapping sound... its really faint, about 4000rpm the engine noise drowns out the noise... hopefully it is a valve adjustment problem?
