tach reading with final drive
Old Mar 18, 2003 | 11:23 PM
BerlinaS2K's Avatar
Default tach reading with final drive
does the tach read right when u get a aftermarket final drive. i know at high speeds the stock one isnt that acurate but does it get worse or is it the same
Old Mar 19, 2003 | 02:55 AM
1Randyc's Avatar
You meant speedometer....
To simply answer your question, with the final gear changed, your speedo will be off. It will read higher than the real speed, for ex: in real it is 55 but on speedo it will read 60.
This also translate to higher reading in odometer.
But you can countermeasure that by installing electronic device aka 'yellow box' to correct the error.
waterscorpion
110
Nov 14, 2006 09:57 PM
waterscorpion
Nov 13, 2006 01:58 AM
trivium
Sep 1, 2006 01:10 PM
REDS2KCA
Jun 3, 2004 02:32 PM
HARDtoTOP
Aug 26, 2002 09:26 AM
