tail light issue
So, last week I noticed that the rear brake light on my wife's s2k was out. I went to honda, bought the light and installed it yesterday. No big deal. However, what I noticed later is that when the brake is depressed, the light works, however, when the headlights are on (meaning the back light comes on), the light doesn't work. What gives? Did I miss something? I checked the bulb, it is fine. any suggestions?
did you buy single or dual filament bulbs?
the rears need dual - sometimes even installing duals the wrong way causes them to only operate singly. if you got the dual, try rotating it 180*
could be a bad contact somewhere. on my dad's lexus there were some pressed on ground wires that after 10 years didnt have any connection which caused the brake lights to turn off when driving at night
this is how it looks when my lights are turned on. however, if i press on the brakes, the circles will go on. i also checked the fuse box and there was nothing labeled "taillights". So which fuse should i check? thanks
