tail light issue
Old Mar 12, 2007 | 08:59 AM
Anrosphynx's Avatar
Default tail light issue
So, last week I noticed that the rear brake light on my wife's s2k was out. I went to honda, bought the light and installed it yesterday. No big deal. However, what I noticed later is that when the brake is depressed, the light works, however, when the headlights are on (meaning the back light comes on), the light doesn't work. What gives? Did I miss something? I checked the bulb, it is fine. any suggestions?
Old Mar 12, 2007 | 10:42 AM
TrackStar's Avatar
Did you check all the bulbs? Check the fuses as well. Some of the fuses for the car do a couple things, and their function may be listed incorrectly
Old Mar 12, 2007 | 11:15 AM
Anrosphynx's Avatar
I did check the other bulbs. They all look ok, but i will check the fuses tonight..
Old Mar 12, 2007 | 12:19 PM
S2000GT's Avatar
did you buy single or dual filament bulbs?
the rears need dual - sometimes even installing duals the wrong way causes them to only operate singly. if you got the dual, try rotating it 180*
Old Mar 12, 2007 | 01:20 PM
Anrosphynx's Avatar
I got the dual filament. Both are still intact.
I will try to flip it tonight and see if that works.
Thanks for the suggestion.
Old Mar 12, 2007 | 06:52 PM
jzz30's Avatar
could be a bad contact somewhere. on my dad's lexus there were some pressed on ground wires that after 10 years didnt have any connection which caused the brake lights to turn off when driving at night
Old Mar 12, 2007 | 07:49 PM
Utah S2K's Avatar
Sounds to me like you may have inadvertently loosed the wire to the passive taillight bulb. Recheck the two connections.....
Utah
Old Jun 23, 2008 | 05:31 PM
ichugum's Avatar
did u ever figure out what was wrong?? i am currently experiencing the same problem. please help! thanks
Old Jun 23, 2008 | 05:43 PM
ichugum's Avatar
this is how it looks when my lights are turned on. however, if i press on the brakes, the circles will go on. i also checked the fuse box and there was nothing labeled "taillights". So which fuse should i check? thanks
Old Jun 23, 2008 | 10:05 PM
Seattle2k's Avatar
Could it be a bad relay? Possibly a short somewhere.
