Taking the car back out from storage question...
Old Mar 9, 2003 | 05:45 PM
matrix's Avatar
I also read somewhere about dropping a little oil in each cylinder, however, I think it is a waste of time (stickly my opinion). Those few drops are going to land on the piston head and not lube the sides. By the time it spreads to the sides I bet the oil pump has done its job....What does everyone think?
Old Mar 9, 2003 | 06:12 PM
darkknight1999's Avatar
I believe the teaspoon information your speaking about has to do with something totally different than what your using it for, but I don't see why a few drop would hurt anything.
I suppose I should tell you the what the oil thing is all about. The way it goes is if your checking for a loss of power and the like, you have to start the process of elimination thing, to find out the cause. So you get the compression tester out and go though each cylinder checking them for the proper compression. You find one or more not holding the proper compression. So how do you know if its the valve seals, the piston rings or something else?...... well that's what the "teaspoon or less" is for(a leak down test). By placing a small amount of oil into the cylinder, should there be a leak around the piston ring('s) the oil will temporarily seal the ring, and raise than raise the compression not fully but enough to help prove the piston ring damage theory. Now if you place that same amount of oil into the cylinder and when you do the rechecking compression test and nothing happens this should have you looking into the valve seal direction or the head gasket (you should be able to tell about the head gasket though by seeing coolant in the oil), because that small amount of oil will not seal a leaking valve seal.
Anyway I hope this help you understand it a little, and as for putting a small amount of oil into each cylinder I'd say you don't have to, won't hurt anything as long as its a very small amount like you said.
-John
Old Mar 10, 2003 | 01:31 AM
NNY S2k's Avatar
[QUOTE]Originally posted by matrix
[B]I also read somewhere about dropping a little oil in each cylinder, however, I think it is a waste of time (stickly my opinion).
Old Mar 10, 2003 | 09:18 AM
WLAURENT's Avatar
Old Mar 10, 2003 | 10:40 AM
Rex's Avatar
Rex
The first time I start mine, when taking it out of storage, I hit the start button very briefly a few times. Just enough to turn the engine, but not start it. My theory is this is enough to splash oil up into the cylinders, without subjecting it to a lot of RPMs.
Old Mar 10, 2003 | 03:58 PM
JonasM's Avatar
[QUOTE]Originally posted by Rex
[B]The first time I start mine, when taking it out of storage, I hit the start button very briefly a few times.
Old Mar 10, 2003 | 04:42 PM
xviper's Avatar
ROTFLMAO
Apr 28, 2009 08:03 AM
JerseyGirl
South Florida
Aug 8, 2003 11:18 AM
thunderchicken
May 29, 2003 09:17 PM
blckndvoodoo
Mar 25, 2002 07:41 AM
stockae92
Jan 3, 2002 03:37 PM
