tct?
Old Jul 12, 2017 | 10:59 PM
jsaric's Avatar
Default tct?
Hello,
need help, i think it is a TCT rattle.
here is video
Thank you
Old Jul 13, 2017 | 05:34 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
TCT, 100%.
Old Jul 13, 2017 | 06:17 AM
Chuck S's Avatar
Unless you're really in Croatia email or PM Bill and get his GenX TCT. It will take you 10 minutes to remove the defective unit and part of that time is finding the 10mm wrench and needle nose pliers. There are several threads on how easy this is to swap.
-- Chuck
Old Jul 13, 2017 | 06:22 AM
jsaric's Avatar
thank you guys.
unfortunately i am in Croatia so Billman's TCT is unreachable for me.
I saw thread on S2ki with sandblasting repair of TCT. What do you think of that solution?
Thanks
Old Jul 13, 2017 | 07:32 AM
THMotorsports's Avatar
Former Sponsor
Originally Posted by jsaric
thank you guys.
Thanks
Quick easy repair.
Old Jul 13, 2017 | 04:05 PM
Chuck S's Avatar
Quick, easy, temporary repair. Problem will recur but you can do it several times from what I read here..
-- Chuck
Old Jul 13, 2017 | 04:34 PM
Billman250's Avatar
Top Answer: 1
Sandblasting the worm has limited success, but it can buy you some time.
Just dont dremel it or sandpaper it. It will work, but when the noise returns it will be a lot worse.
Old Jul 13, 2017 | 11:55 PM
jsaric's Avatar
on my work i have sandblasting with metal girt.
like this on picture
should i blast it using sand or this metal grit will be ok?
at the moment i am looking for someone in USA so i can buy billman's TCT.
Old Jul 14, 2017 | 03:54 AM
Billman250's Avatar
Top Answer: 1
Definitely use sand.
Old Jul 14, 2017 | 06:19 AM
jsaric's Avatar
Ok,
thank you
