TCT Fix
Old Jul 14, 2021 | 09:56 AM
kunoshilloz1's Avatar
Default TCT Fix
Hi so I've opened up my TCT and sanded down the worm gear with a grade 180 sandpaper roll (couldnt find a sandblaster) and now Im stuck because I cant find a bolt to keep the piston retracted (the one with the wing nut). Can I install it like that?
Do I have to spin the worm gear as down as it can go?
Old Jul 14, 2021 | 10:05 AM
blixhavn's Avatar
You'll need an M4or m5 bolt, nut and washer. Spin the TCT Down as far as you can get it, then screw in the bolt with a washer and nut already screwed on it 5 or 15 threads, spin the washer and nut down so it's tight and let go... Install the main body, remove the nut/bolt/washer, install the cap back on it
Sorry i dont remember if it's m4 or m5, if memory serves me correct its m5 x .75
Old Jul 14, 2021 | 10:33 AM
Thanks, is it possible to put the tct back on without it?
Old Jul 14, 2021 | 10:57 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
No. You cannot install the tensioner without retracting it. Doing so will destroy the engine beyond repair.
Retracting bolt is 5mm .80 thread, about 1.750 inches long, or longer.
Old Jul 14, 2021 | 11:13 AM
Slowcrash_101's Avatar
Just get a Billman unit. Save yourself endless headaches. It's a one time charge and you never have to worry about your chain for the life of the engine. Cheaping out on engine parts can get expensive.
Old Jul 14, 2021 | 11:17 AM
I'd love to but I dont live in the US
Old Jul 21, 2021 | 07:28 AM
jackmugen02's Avatar
Former Sponsor
Buy a Toda Racing TCT from RHDJapan.
Old Jul 28, 2021 | 04:21 PM
gumbys2k's Avatar
jack knows
echofilter
Aug 21, 2015 06:19 AM
#1turbos2k
Dec 26, 2010 05:15 PM
dulslo666
Apr 16, 2009 09:56 AM
vonHultgren
Oct 8, 2007 11:59 AM
