TCT replacement
You DO NOT have to pull the charger, you don't even need to use the maintenence hole.
Just retract the new tensioner with the bolt/nut combo and install it.
It took me 20 minutes to do an S/Ced car.
In other words:
-remove top cap from tensioner
-remove oil nozzle with flat screwdriver
-lock tensioner with bolt/nut combo as instructed in the manual
-remove locking pin (comes installed in new tensioner only)
-install tensioner, tighten mounting bolts
-remove nut/bolt combo, tensioner will extend
-replace oil nozzle
-replace top cap
-replace oil nozzle
-replace top cap
