Technical question
Old Feb 26, 2015 | 12:25 PM
Slowcrash_101's Avatar
Default Technical question
How much engine damage is caused by starting a car after a fresh oil change with no oil in the filter? Should one run the starter with the fuel relay disabled to prime the oil pump to avoid this? If not are there any suggestions as to how to avoid that nasty sound after a fresh oil change start-up?
Just curious.
Old Feb 26, 2015 | 12:39 PM
Sylvan's Avatar
I put quite a bit of oil in my new filter before spinning it on (not totally full of course). I can usually spin it on quickly enough to avoid spilling much, if any at all.
Old Feb 26, 2015 | 12:47 PM
bgoetz's Avatar
This has been discussed, I actually think I posted something asking the same thing. The end result is most do not prime the filters, but some do. If the engine has been ran recently the amount of oil coating the surfaces should be plenty adequate. I changed mine cold once, I don't recall why, but I did. In that situation I can maybe see a bit of extra wear, but I doubt it is anything crazy. At the end of the day I decided to prime the filters from now on, at least soak the element, it isn't that messy and it can't hurt anything
Old Feb 26, 2015 | 05:40 PM
Utah S2K's Avatar
The obvious answer is to fill the filter like the manual says. If you forget, which I have, damage most likely won't occur. Ask me how I know.
Utah
P.S. I now manually turn the crank over when I take her out of winter hibernation. While replacing my AP1 retainers to AP2 I found out just how effective manually turnover is in lubing the top end
Old Feb 26, 2015 | 06:04 PM
climhazzard's Avatar
I didn't realize the manual specified adding oil to the filter prior to installation...interesting.
Old Feb 27, 2015 | 10:12 AM
Sylvan's Avatar
It actually shows it on the filter itself. There are little graphics that indicate adding oil to the filter, and then oiling the gasket, then spin it until it's touching the flange plus 7/8 of a turn.
Old Feb 27, 2015 | 11:59 AM
But it's impossible to fill the filter to capacity, some will fall out.
Old Feb 28, 2015 | 09:23 AM
I just took a look at an OEM filter I have sitting on the shelf, and it only specifies adding oil to the filter gasket, not in the oil filter itself. I haven't yet checked the shop/service manual though.
Old Feb 28, 2015 | 01:01 PM
Sylvan's Avatar
You're right I just looked at mine too, I guess I had it mixed up in my head. I just looked in the service manual and it also does not mention putting oil in the new filter, only a light coat on the filter gasket. Oh well, I will still do it out of habit.
Old Feb 28, 2015 | 02:50 PM
Utah S2K's Avatar
Interesting. The shop manual doesn't say to do it ( I thought it did). I have always done it and thought it was standard practice. Probably learned it high school auto.
Utah
