Tein Flex Squeaking
Old Jul 22, 2006 | 11:19 AM
slam126's Avatar
Default Tein Flex Squeaking
Does anybody have a solution or a similar problem? Every time I go over a speed bump or even a bumpy stretch of road there is a squeaking sound. I've lubed ever possible place and I know it's not the spare tire or the front hood. Can someone please help
Old Jul 22, 2006 | 11:29 AM
omgvtec's Avatar
I get the odd squishy sound out of my flex's in the front, at low speeds when i go over speed bumps. I've always wondered about this.
Old Jul 22, 2006 | 12:09 PM
Dark's Avatar
It could be the coils rubbing together. Have you checked the strut rod for grease streaks?
You can try putting some type of lubricant (wd-40 for example) on the coils (dont get any on the strut rod) to see if it goes away (may only be temporary).
wd-40 may be a bad example since it attracts dirt.
Old Jul 22, 2006 | 08:16 PM
dtang21's Avatar
Do you have aftermarket sway bars? Those polyurethane bushings might need some lube. I had a similar problem but it turned out to be the sways and not the coils.
Old Jul 23, 2006 | 11:08 AM
slam126's Avatar
Nope, OEM sway bars.
Old Jul 24, 2006 | 08:15 AM
CosmosMpower's Avatar
I am experiencing the same problem with stock springs/shocks with the whiteline FSB but it squeaks at all 4 corners. I silicone lubed all the bushings/rubber parts and it won't go away.
Old Jul 24, 2006 | 03:17 PM
camera obscura's Avatar
The same issue came up with my Flex's about a week ago after I adjusted the upper damper controllers on all four corners from 8/12 to 6. Havn't had time to investigate, thought. Did you just change yours?
Old Jul 25, 2006 | 02:51 PM
tharza469's Avatar
mine does it in the rear, it is the plastic black part that goes over the strut behind the coil to help prevent dirt and stuff from getting in the strut
MinS2K
Sep 3, 2008 08:52 PM
rdv5434391
Jan 31, 2008 10:25 AM
TCLAP2
Nov 21, 2007 10:00 PM
jchung
25
Oct 23, 2006 09:11 PM
ptype
Jul 5, 2006 06:25 PM
